19 years agohowto build a openssl Version 0.9.8d
Hello everyone:
I try to build a new version of openssl 0.9.8d with the target build_libs. The Makefile comes to an end without error messages. Therefor i add in the Configure file the following line: "altera","nios2-linux-uclibc-gcc:-O3 -fno-pic -Wall -DTERMIO -DBN_STRICT -DPURIFY -DL_ENDIAN -D_FILE_OFFSET_BITS=32 -mhw-mul::-D_REENTRANT:::BN_LLONG ::http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ", I use nios2-linux-uclibc-gcc version 3.4.6. Using my own libssl/libcrypto my system crashes with BAD-MAC error and enryption is very slow Using the libcrypto from "hippo" everything is ok. (nios2libs.tar.bz2) But this is an old Version. Who to compile/configure a new openssl? Which flags are needed? Can someone help me?1 Reply
I built the old version with buildroot.
You may look at the makefiles in buildroot/package/openssl . I remove the thing about shared objects. It should be possible to change them to newer verion.
