16 years agoHowever, the TSE MAC driver is not ready yet, and the ethernet won't work.
Hi, I have seen there words on the Wiki about the uclinux: "However, the TSE MAC driver is not ready yet, and the ethernet won't work." I use NEEK.So that means I can not use TCP/I...
16 years ago --- Quote Start --- I use NEEK.So that means I can not use TCP/IP stack to do the communication using ethernet if I use uclinux OS from the Wiki? Right? --- Quote End --- In the Wiki there is a binary uCLinux demo (ZIP file), loadable from the SD-Card by the NEEKs "Altera Loader"s menu, that uses TCP/IP over Ethernet (on the "Open Ethernet" driver). -Michael
