20 years agohow towrite makefile for driver?
hello friend
i am using nios IDE.i have written module.c and makefile like CODE: ifneq ($(KERNELRELEASE),)# kbuild part of makefile obj-m := module.o else# Normal Makefile ARCH := nios2nommu CROSS_COMPILE := nios2-elf- KERNEL_PLUGIN:= /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0 KERNELDIR := $(KERNEL_PLUGIN)/linux-2.6.x BUILDDIR := /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/workspace/jay_07_07/build/include all:: $(MAKE) -C $(KERNELDIR) M=`pwd` O=$(BUILDDIR) modules endif and i copy module.c and makefile in my linux application project. but when i build it then i get following messege on ide console.. make -k all make -C /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x M=`pwd` O=/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/workspace/jay_07_07/build/include modules make[1]: Entering directory `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/Makefile:486: .config: No such file or directory /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/Makefile:531: /cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/i386/Makefile: No such file or directory gcc: not found gcc: not found make[2]: *** No rule to make target `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/i386/Makefile'. make[2]: Failed to remake makefile `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/i386/Makefile'. CC [M] /cygdrive/e/working_file/test_07_07/module.o gcc: not found make[3]: *** [/cygdrive/e/working_file/test_07_07/module.o] Error 127 make[3]: Target `__build' not remade because of errors. make[2]: *** [_module_/cygdrive/e/working_file/test_07_07] Error 2 make[2]: Target `modules' not remade because of errors. make[1]: *** [modules] Error 2 make[1]: Leaving directory `/cygdrive/d/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' make: *** [all] Error 2 please help me what i have to next..3 Replies
Well look in the forum
http://forum.niosforum.com/forum/index.php...wtopic=2655&hl= (http://forum.niosforum.com/forum/index.php?showtopic=2655&hl=) http://forum.niosforum.com/forum/index.php...wtopic=2411&hl= (http://forum.niosforum.com/forum/index.php?showtopic=2411&hl=) this has already been done by a lot people. Good Luck - Altera_Forum
--- Quote Start --- originally posted by helmchen@Jul 7 2006, 08:02 PM well look in the forumhttp://forum.niosforum.com/forum/index.php...wtopic=2655&hl= (http://forum.niosforum.com/forum/index.php?showtopic=2655&hl=)
good luck
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16713)
--- quote end ---
--- Quote End --- hi helmchen i have folowed your given lonk.and i got module.ko. then i have include module.ko in filesystem-romfs(/home) then using nios ide ,i have generated romfs.bin. i have load romfs and kernel on my board,but when i try to instole module it is not allowing to it,it is giving following mess. none) login: nios2 nios2 Password: uClinux # cd /bin cd /bin # ls ls agetty busybox cat echo expand init kill login ls mount ps pwd sh sync umount # cd .. cd ..# cd home cd home# ls ls ftp module.ko # busybox insmode module.ko busybox insmode module.ko insmode: applet not found# where am i wrong? please help me .
Nice to see that you were sucessfull.
try insmod instead of insmode. In addition i would propose to make a ftp connection to transfer your files (programs and module) on your board. It is much easier than to include the new file to your filesystem and upload to your board again and again and again and again... :-). nfs would work, too.
