19 years agoHow to write HAL ISRs for custom components
Hi experts,
I created a custom component in the Component Editor and added it in a system containing only the Nios II and the component. I can write data from the Nios to my component; this is working. Now I want my component to interrupt the CPU so that it reads from the component. How can I access the Nios registers containing the information about interrupts? I read in Ch. 5 of the Nios SW Handbook about developing HAL drivers but couldnt get any information on how to register an interrupt. Any help or hints would be appreciated... Thanks in advance!2 Replies
I also encounter problems with hardware custom components interrupts. Could someone help us ? Thanks ! Regards. - Altera_Forum
Basically, to register your ISR you do
alt_irq_init // enable irqs in control register 3 (nios proc ref book, chapter 3) alt_irq_register // tie your ISR alt_irq_enable // enable your IRQ That should work. __________ If you want to access CPU registers, you can use functions like: alt_irq_pending (or NIOS2_READ_IPENDING), alt_irq_enabled, alt_irq_enable, alt_irq_disable etc Check the alt_irq.h for the reference. Good luck
