16 years agoHow to write floating-point value to custom logic???
Hi all,
I worte a component which is using altfp_sqrt of megafunction, then I checked the simulation with avalon interface signal, it's match the timing and need 17 cycles. All configurations are set in sopc. BUT in nios, when I wrote the floating-point data using IOWR, the sqrt component did not compute. My code is under below # include <stdio.h># include <float.h># include <unistd.h># include "system.h" int main() { float data_in = 2.0; float ans; IOWR(SQRT_BASE, 0, data_in); //regnum = 0 is data_in usleep(1);//because 17 cycle delay ans = IORD(SQRT_BASE, 1); //regnum = 1 is calculate result printf("%f\n", ans); return 0; } The value will show 0.000000 If I change the data format such like this: unsigned in data_in = 0x40000000; //IEEE-754 format, equivalence 2.0 unsigned int ans; So, I can get the correct value, but the data type is NOT floating-point If I want to use custom logic to calculate floating-point in NIOS, how to solve this problem??? thanks all3 Replies
You can use a function to copy hexadecimal values using the address like that :
And you call it as following :unsigned long F32ToHex (float valueF) { unsigned long* valueL = (unsigned long*) &valueF; return *valueL; }
Jérômefloat value = 678.482; unsigned long hexValue; hexValue = F32ToHex(value); IOWR(SQRT_BASE, 0, hexValue); - Altera_Forum
Except that such code breaks the 'strict aliasing' rules of C, and gcc might optimise away the assignment.
Better would be a cast on the LHS, eg: *(volatile float *)SQRT_BASE = data_in; An alternative is to define a C structure, and variable of a type that matches the IO device, and then get the linker to assign a fixed address (or use a pointer). eg:
IMHO using structures to access hardware devices is much less error prone than trying to use constants and access macros. Although not 100% portable, it is portable enough.extern struct { volatile float sqrt_in; volatile float sqrt_out; } *sqrt_device = (void *)(1u << 31 | SQRT_BASE); ... sqrt_device->sqrt_in = data_in; delay(); printf("%f\n", sqrt_device->sqrt_out); - Altera_Forum
THANKS LETS and dsl!!!
My problem SOLVED TOTALLY!!! The function work out fine!!! Thank you very much!!!
