16 years agoHow to write floating-point value to custom logic???
Hi all, I worte a component which is using altfp_sqrt of megafunction, then I checked the simulation with avalon interface signal, it's match the timing and need 17 cycles. All configurations are ...
16 years agoExcept that such code breaks the 'strict aliasing' rules of C, and gcc might optimise away the assignment.
Better would be a cast on the LHS, eg: *(volatile float *)SQRT_BASE = data_in; An alternative is to define a C structure, and variable of a type that matches the IO device, and then get the linker to assign a fixed address (or use a pointer). eg:
extern struct {
volatile float sqrt_in;
volatile float sqrt_out;
} *sqrt_device = (void *)(1u << 31 | SQRT_BASE);
sqrt_device->sqrt_in = data_in;
delay();
printf("%f\n", sqrt_device->sqrt_out);
IMHO using structures to access hardware devices is much less error prone than trying to use constants and access macros. Although not 100% portable, it is portable enough.
