21 years agoHow to write eCos application on flash?
Hi! I have generated the eCos package, and an application. I've been running it with the IDE environment and the "Run"command, since now. Now I have to write it to flash. The idea is...
21 years agoI've done it!
The fact is that it wasn't the SOF file, because I am not able to write using the flash-prgrammer (I don't know exactly why, but I've heard it's something about a reset pin used to anything "usual" in my board). So now I'm writing the flash using the germs program, with to different Nios, Nios1 and Nios2, in the same chip. Depending on a strap, it boots with Nios1 and germs, or it boots with Nios2. I think the problem with my previous generations was that the size was incorrect, and somehow, in the generated file, there was only the bootloader. Today I've done all the steps again, with the correct size, and it works. Thank you. Alex
