19 years agohow to write device driver under uClinux
if I add a device IP to SoPC,how can I write a driver to drive this device under uClinux?Who can help me?Thanks!
19 years ago --- Quote Start --- originally posted by hippo@Dec 26 2006, 09:49 AM you should develope uclinux on a linux pc.
and don't mix-up kernel module and user apps, thought they all called hello.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20225)
--- quote end ---
--- Quote End --- Hi hippo: I develop the nios under windows,using nios II IDE,and microtrnix uclinux.I use the hello driver programme in the web you gave,and do what it said,then I write an application to call the hello driver,it failed,the error is "can't find hello driver". if I call "dev/mem" driver which had existed,it succeed. why did I fail to add the hello driver module to uClinux?Is there anything else I need to do ?
