How to write data into the SDRAM present as a part of simple socket server that has NIOS processor?
Hi @APaga1,
Thank you for posting in Intel community forum and hope you are doing well, regards to the question that you have on the memory address in the bsp setting, the reset vector seem correct, and if you are suspecting the address are in correct, you may refer to the steps to modify those address in the bsp setting in the section (5.4.2.2). More details of the linker memory can also be found here.
Just curious, what are the targeted device that you are working on?
Warm regards.
Thank you for your reply. I am using Cyclone V GT device. In general, how do I write data into the SDRAM present using NIOS?
- BoonBengT_Altera5 years ago
Moderator
Hi @APaga1,
Good day, in general we would need a controller for that.
You may refer to the sample reference design here, it is for other cyclone board, but I believe the concept of design are the same.Warm regards.
Moderator
Hi @APaga1,
Hope this message find you well and good day, as we do not receive any response from you to the previous clarification that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
