21 years agoHow to write a makefile to compile C project ?
Hi all !
I'm using Cyclone 1c12 eval, Microtronix uCLinux 1.4, NIOS II IDE 5.0 I have a C project (which will run on uCLinux) as following: header files: libA.h libB.h . . . c files: a.c b.c c.c . . . main.c // <-- this file contains function main() How can I write a makefile ( makefile & rule.mak ) for above project or edit the Microtronix template ? Thank you OneNet3 Replies
Hi OneNet,
> How can I write a makefile ( makefile & rule.mak ) for above project First read the Linux Reference Guide section, "Creating a Makefile" ... basically, you just need to include the Rules.mak and pretty much do what you would always do. E.g.:
Regards, --ScottTARGET = foo.exe CSRC = foo.c bar.c OBJS = $(CSRC:.c=.o) # All object files LDFLAGS += # ################################################################# .PHONY: default install clean realclean distclean depend default: deps $(TARGET) install: cp -pf $(TARGET) $(BIN_INSTALL) clean: rm -rf $(OBJS) core distclean: clean rm -f deps rm -rf $(TARGET) depend: deps sinclude deps include Rules.mak - Altera_Forum
Sorry, I must have fat fingered the following (missing from above):
--Scottdeps: Makefile $(CSRC) $(CC) -M $(CFLAGS) $(CSRC) > deps - Altera_Forum
Dear scott !
Your solution is very clear ! thank you so much OneNet
