13 years agohow to write a costum gpio interrupt driver
I want to write a custom gpio interrupt driver. I just want to trigger the led in interrup handle function. In my probe function I register interrupt and initial the registers. I can see the int...
11 years ago --- Quote Start --- Thanks in advance. I'm having trouble compiling my custom device driver. I'm using the 14.1 tools. My compiled linux is in /home/user1/linux-socfpga My cross compiler is in /home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf- My device driver is in /home/user1/newDriver I'VE TRIED LOTS OF THINGS - and googled for a few hours One was -- from the newDriver directory I tried:# ] make ARCH=arm CROSS_COMPILE=/home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf- KERNEL_SRC=/home/user1/linux-socfpga IT TRIES BUT CAN'T FIND the kernel header files. Any help would be greatly appreicated. --- Quote End --- SOLUTION: Here is the Makefile KERNEL_DIR=/home/user1/linux-socfpga obj-m := testDriver.o PWD := $(shell pwd) default: $(MAKE) M=$(PWD) ARCH=arm CROSS_COMPILE=/home/user1/gcc-linaro-arm-linux-gnueabihf-4.8-2013.12_linux/bin/arm-linux-gnueabihf- -C $(KERNEL_DIR) SUBDIRS=$(PWD) modules clean: $(MAKE) -C $(KERNEL_DIR) SUBDIRS=$(PWD) clean
