11 years agoHow to verify that my Analog Digital Converter (ADC) is giving the correct result
Hi there, I have created Analog Digital Converter (ADC) as custom component interfacing with Nios ii using Altera Monitor Program. I am using Terasic DE0-Nano Cyclone IV. The ADC model is NS ...
11 years ago --- Quote Start --- To verify it is correct, you will need to measure voltage levels on the board, to check against the expected values in your FPGA. --- Quote End --- Tricky, thanks for your reply... How could I use RS232 UART to send data to my ADC and to show the converted value on the screen in order to verify the results? I know I am blur on this, very bad understanding in hardware, forgive me I think my question is how can I use RS232 UART to verify the results (converted digital outputs match the analog inputs)?
