20 years agoHow to use
i m using alt_avalon_spi_command() now, and i did it according to Altera Embedded Peripherals Handbook chapter 7. I m looking using SPI to transfer some data to another board. And i can't figure out how to use this command line.
int alt_avalon_spi_command(alt_u32 base, alt_u32 slave, alt_u32 write_length, const alt_u8* wdata, alt_u32 read_length, alt_u8* read_data, alt_u32 flags) 1) Where can i find what value i should put for alt_u32 slave? 2) What value should i put for flag? 3) If i m going to just send the data, in MOSI mode, what value should i put for read_length and read_data? 4) do you have an example demostrating how to use this command ? I just can't get it to work on Nios II cyclone board. how is i wrote the code _______________________________________________________ /* alt_u8 sending[16] = { 0x81, 0xCF, 0x92, 0x86, 0xCC, 0xA4, 0xA0, 0x8F, 0x80, 0x84, 0x88, 0xE0, 0xF2, 0xC2, 0xB0, 0xB8 }; alt_u8 receiving[16]; download= alt_avalon_spi_command(0x00800000,1,16, sending,16, receiving,1); _______________________________________________________ and the output has no signal coming out. I can't figure out anything goes wrong.3 Replies
--- Quote Start --- originally posted by wei_chen0428@Mar 14 2006, 05:06 AM int alt_avalon_spi_command(alt_u32 base, alt_u32 slave,alt_u32 write_length, const alt_u8* wdata, alt_u32 read_length,
1) where can i find what value i should put for alt_u32 slave?
2) what value should i put for flag?
3) if i m going to just send the data, in mosi mode, what value should i put for read_length and read_data?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13399)
--- quote end ---
--- Quote End --- May You see source code of "altera_avalon_spi.c" ? If you can do it you can find out function alt_avalon_spi_command. And see all information about this function and its variables. I recommend you read manual about SPI in SOPC builder
--- quote end ---
--- Quote End --- 1. alt_u32 slave is the number of slave connected to your master, with the first one starting from "0", as pointed out in the documentation. 2. Flag = ALT_AVALON_SPI_COMMAND_MERGE, if you wish to use that function, else put 0.
--- Quote Start --- [/b] --- Quote End --- 1. alt_u32 slave is the number of slave connected to your master, with the first one starting from "0", as pointed out in the documentation. So if I have 4 slaves connected to the SPI master, I should set slave =0x03? I think this argument is used to select which slave I want to write or read, e.g.: if I want to read or write slave 0, I should set slave = 0x00, correct? Thanks.
