21 years agohow to use vhdl program in the NIOS?
pls give me a simple example about how i can add a vhdl program to the nios cpu ? what is format of the vhdl program ?
21 years agoYou should first create an IUL between your VHDL and Nios system. Then you create a block symbol of your VHDL if necessary. Finally assign the linking pins correspondingly.
