21 years agohow to use timer
hello all
I use the timer core ,but when i write the timer there is something wrong with it . my programm is : void handle_time_interrupt() { IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE, 0x0b); count++; if(count==1) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xfe); } if(count==2) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xfd); } if(count==3) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xfc); } if(count==4) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xfb); count=0; } } void init_time() { IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE, 0x07); alt_irq_register( TIMER_0_IRQ , NULL, handle_time_interrupt ); } int main() { count=0; IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xaa); init_time(); while (1) { } return 0; } the time is 5 second,and i only see the result of 0xfb,cann't see the oxfd and 0xfc6 Replies
I suspect that your problem is that a driver is using the timer at the same time as your code, which is not a good position to be in. You can confirm this by looking in the file alt_sys_init.c if you find a MACRO TIMER_0_INIT then my diagnosis is correct.
You should read the Nios II Software Developers Handbook to learn more about the automaticallt installed drivers and how to remove them. - Altera_Forum
hello
the handbook is too large,can you tell me which chaper should i see. thanks - Altera_Forum
For details of how the initialisation sequence performed by the function alt_sys_init() works I suggest you load up the software developers handbook and search (Ctrl-F) for the string alt_sys_init.
This will provide you with the information you need. - Altera_Forum
hello
i had seen the alt_sys_init(),but it can not solve my problem. Do you have any other suggestion? thanks. - Altera_Forum
I'm not sure what you mean by I had seen the alt_sys_init. If alt_sys_init has any timer calls in it, this will be your problem
hello:
i find the ALTERA_AVALON_TIMER_INIT( TIMER_0, timer_0 ) in the alt_sys_init();And try to remove it but it failed. it automatically generate the contents of alt_sys_init.c.How can i. Could you tell me the way? thanks.
