10 years agohow to use the floating point hardware in nios II custom instructions
hi
i want to compare the speed difference of floating point calc between custom instruction floating point and software. this is my code:# include <stdio.h># include <altera_avalon_pio_regs.h># include "altera_avalon_pio_regs.h"# include "system.h" int main() { printf("Hello from Nios II!\n"); float a=3.1415926; float b=1.2578; float c=0; while(1) { IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0xf); c=a*b; IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0x0); c=a-b; IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0xf); c=b-a; IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0x0); } return 0; } in the code,i use pio to estimate the calc time roughly, firstly, i delete the floating point hardware, generate the hdl, compile the quartus project, build the software, then i find the calc time is 2.3us(the sys clk is 100M); then, i add the floating point hardware, and redo these steps, i find the calc time is still 2.3us i guess the nios did not use the floating point hardware, how can i fix this problem? is there any examples to show me how to use it? thanks!14 Replies
thank you very much!
when i change the system.h file, the objdump file becomes: c=a*b; 1082c0: e13ffd17 ldw r4,-12(fp) 1082c4: e17ffe17 ldw r5,-8(fp) 1082c8: 01083c00 call 1083c0 <__mulsf3> 1082cc: 1007883a mov r3,r2 1082d0: e0ffff15 stw r3,-4(fp) c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); //* 10832c: e0bffe17 ldw r2,-8(fp) 108330: e0fffd17 ldw r3,-12(fp) 108334: 10c5ff32 custom 252,r2,r2,r3 108338: e0bfff15 stw r2,-4(fp) and the c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); return the right result, and the calc time is much lesss than the c=a*b how do you know to change the inii to fnff in system.h file? i am new to altera and nios, i want to learn more. it seems like my project still has some problems, but at least i know how to use the floating point hardware in nios II custom instructions but i still do not understand why the system.h in my project have to change manually? and why i can not use c=a*b. may be i can try floating point hardware2. thanks again! - Altera_Forum
I think somehow the following lines are not included into your public.mk file found in your BSP folder:
# Hardware Floating Point Custom Instruction without Divider present. ALT_CFLAGS += -mcustom-fpu-cfg=60-1 ALT_LDFLAGS += -mcustom-fpu-cfg=60-1 What Quartus version are you using? I guess you could open nios2-bsp-editor in the BSP folder and add "-mcustom-fpu-cfg=60-1" into the bsp_cflags_user_user_flags under main>>advanced tab. Or try to create a new BSP...... The Altera Nios II GCC supports the following builtin functions: https://gcc.gnu.org/onlinedocs/gcc/altera-nios-ii-built-in-functions.html I guess I am a curious person that likes to try to understand things. - Altera_Forum
i use quartus 15.0
this is what my public.mk shows :
# Hardware Divider present. # setting HARDWARE_DIVIDE is false ALT_CFLAGS += -mno-hw-div # Hardware Multiplier present. # setting HARDWARE_MULTIPLY is true ALT_CFLAGS += -mhw-mul # Hardware Mulx present. # setting HARDWARE_MULX is false ALT_CFLAGS += -mno-hw-mulx ...... # Enable BSP generation to query if SOPC system floating point custom # instruction with a divider is present. If true ignores export of 'ALT_CFLAGS # += -mcustom-fpu-cfg=60-2' and 'ALT_LDFLAGS += -mcustom-fpu-cfg=60-2' to # public.mk if the custom instruction is found in the system. none # setting hal.make.ignore_system_derived.hardware_fp_cust_inst_divider_present is false there are no "# Hardware Floating Point Custom Instruction without Divider present. ALT_CFLAGS += -mcustom-fpu-cfg=60-1 ALT_LDFLAGS += -mcustom-fpu-cfg=60-1" in my project , the bsp editor=>settings=>advanced=>hal.make.ignore_system_derived i found the "hardware_fp_cust_inst_no_divider_present" is checked, i think maybe that is the reason, so i uncheck it, then regenerate the bsp rebuild the project, change the system.h again(the soft ware generate the "__builtin_custom_inii" again, i have to change it to "__builtin_custom_fnff" manually) then i find in objdump file: c=a*b; 1082c0: e0fffd17 ldw r3,-12(fp) 1082c4: e0bffe17 ldw r2,-8(fp) 1082c8: 1885ff32 custom 252,r2,r3,r2 1082cc: e0bfff15 stw r2,-4(fp) so problem solved! so it seems like if i want to use the floating point hardware in nios II custom instructions, i have to add the ip in Qsys=>change the bsp setting=>change the system.h why the user guide did tell me? "tt_floating_point_custom_instructions.pdf"
