10 years agohow to use the floating point hardware in nios II custom instructions
hi i want to compare the speed difference of floating point calc between custom instruction floating point and software. this is my code:# include <stdio.h># include <altera_avalon_pio_regs....
10 years agoI think somehow the following lines are not included into your public.mk file found in your BSP folder:
# Hardware Floating Point Custom Instruction without Divider present. ALT_CFLAGS += -mcustom-fpu-cfg=60-1 ALT_LDFLAGS += -mcustom-fpu-cfg=60-1 What Quartus version are you using? I guess you could open nios2-bsp-editor in the BSP folder and add "-mcustom-fpu-cfg=60-1" into the bsp_cflags_user_user_flags under main>>advanced tab. Or try to create a new BSP...... The Altera Nios II GCC supports the following builtin functions: https://gcc.gnu.org/onlinedocs/gcc/altera-nios-ii-built-in-functions.html I guess I am a curious person that likes to try to understand things.
