20 years agoHow to use the CF in EP2C35(DEV kit)
Dear Hippo Thank you for your help ,now I have run the linux in my board . Now I want to use the CF card in my board. can you tell me how to do it . My board is the NIOSII EP2C35( al...
20 years agoDear HIppo
Now I have select drivers->ata->altera CF in kernel config, so I get The Next Information when the system boot. <div class='quotetop'>QUOTE </div> --- Quote Start --- smc_probe: 85000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x81000300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:0f:61:8e smc_probe: 85000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 hda: Hitachi XXM2.3.0, CFA DISK drive ide0 at 0x81011000-0x81011007,0x81011038 on irq 7 NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) NET: Registered protocol family 1 Freeing unused kernel memory: 2036k freed (0x4160000 - 0x435c000) init started: BusyBox v1.1.1-pre0 (2006.03.06-16:49+0000) multi-call binary BusyBox v1.1.1-pre0 (2006.03.06-16:49+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # [/b] --- Quote End --- the kerner have check the CF card . <div class='quotetop'>QUOTE </div> --- Quote Start --- ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 hda: Hitachi XXM2.3.0, CFA DISK drive ide0 at 0x81011000-0x81011007,0x81011038 on irq 7[/b] --- Quote End --- Now I shoud mount it but i don't know which node is the CF card. first i have select the VFAT in the kernel config <div class='quotetop'>QUOTE </div> --- Quote Start --- # cat /proc/filesystems nodev sysfs nodev rootfs nodev bdev nodev proc nodev sockfs nodev pipefs nodev futexfs nodev tmpfs nodev ramfs vfat nodev autofs[/b] --- Quote End --- but i find i got the next error <div class='quotetop'>QUOTE </div> --- Quote Start --- # mount -t vfat /dev/hda /mnt mount: Mounting /dev/hda on /mnt failed: No such device or address# [/b] --- Quote End --- pls help me ! thanks!
