20 years agoHow to use Strstix network
hi~~ Please ask! i want use the network to spread the number to mp computer server~~~Strstix pc~~~~~Borland c++ so~How to start? Where to have materials and can be cons...
20 years ago --- Quote Start --- originally posted by dannyjacobs@Dec 5 2005, 08:10 AM hi superstyle1,
i tried to start the same way like you. here's what to do:
download lwip1.0.0 from the download section and try get the webserver design exmple up and running.
then download the following document:
www.sics.se/~adam/lwip/doc/lwip.pdf
try to understand the working of the lwip stack. then use udp or tcp, whatever you like the most
good luck.
danny
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11324)
--- quote end ---
--- Quote End --- Of course this will only work when you use the NIOS II IDE, but it gives you a good example of how it works... Cheers, Danny
