21 years agohow to use nios2_germs_monitor.s
I use niosII, I can use flash programmer to write programmer to flash device! But now I have to write a big file to a assigned address of flash device, I belive germs_monitor can do that! ...
21 years agoStart the Nios II IDE. From the Main Menu select Tools -> Flash Programmer, if you need help Select Help -> Help Contents expand the Nios II IDE Help and under Reference you will find Flash Programmer, this should get you started.
