20 years agohow to use "msgget" in nios2 uclinx?
hi:
I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed. After exec, but the return value is -1 I want to use cmd "IPCS" to check the ipc ID. but shell return: not found. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif How can I do? The same function "msgget" used in other uClinx os is OK. Why failed in nios2 uClinux? Why the cmd "IPCS" not support nios2 linux? Thanks a lot.13 Replies
--- Quote Start --- originally posted by hippo@May 11 2006, 09:11 PM please check ~/apps/mqueue .<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15310)
--- quote end ---
--- Quote End --- I make ~/apps/mqueue but failed. So I rework the Makefile of mqueue . But I meet a question. If I want to use mqueue ,frist I must make ~/apps/mqueue/src to make libmqueue.a So I added "ar = nios2-linux-uclibc-ar' id makefile. but in make process, the cc use gcc not nios2-linux-uclibc-gcc,so the libmqueue.a is wrong.
--- Quote Start --- originally posted by alex824+may 12 2006, 02:51 pm--><div class='quotetop'>quote (alex824 @ may 12 2006, 02:51 pm)</div>--- quote start ---
<!--quotebegin-hippo@May 11 2006, 09:11 PM please check ~/apps/mqueue .
--- quote end ---
--- Quote End --- I make ~/apps/mqueue but failed. So I rework the Makefile of mqueue . But I meet a question. If I want to use mqueue ,frist I must make ~/apps/mqueue/src to make libmqueue.a So I added "ar = nios2-linux-uclibc-ar' id makefile. but in make process, the cc use gcc not nios2-linux-uclibc-gcc,so the libmqueue.a is wrong. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15316)</div> [/b] --- Quote End --- Please look at download/mx140apps.diff, and modify the Makefile.
--- Quote End --- Please look at download/mx140apps.diff, and modify the Makefile. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15319)</div> --- Quote End --- Thanks hippo. I have already rework ~/app/mqueue fo following mx140apps.diff. But the mx140apps.diff not dabble at the link *.A . Can you give us a template?
