20 years agoHow to use jffs2 in flash ?
hi hippo
I can cp -a some dirs to /mnt on uclinux with using initramfs. In other word, i have build rootfs in my flash(mtdblock0)that can mount it to /mnt dir, and i can see some dirs in /mnt dir. <div class='quotetop'>QUOTE </div> --- Quote Start --- BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # mount -t jffs2 /dev/mtdblock0 /mnt# cd /mnt# ls -l# mkdir proc sys var tmp mnt# cp -a /init /etc /dev /bin /sbin /usr /root /home /opt .# ls -l drwxr-xr-x 2 root root 0 Nov 29 17:00 bin drwxr-xr-x 6 root root 0 Nov 29 17:00 dev drwxr-xr-x 4 root root 0 Nov 29 17:00 etc drwxr-xr-x 3 root root 0 Nov 29 17:00 home lrwxrwxrwx 1 root root 10 Nov 29 17:03 init -> /sbin/init drwxr-xr-x 2 root root 0 Nov 29 17:01 mnt drwxr-xr-x 2 root root 0 Nov 29 17:00 opt drwxr-xr-x 2 root root 0 Nov 29 17:01 proc drwxr-xr-x 2 root root 0 Nov 29 17:00 root drwxr-xr-x 2 root root 0 Nov 29 17:00 sbin drwxr-xr-x 2 root root 0 Nov 29 17:01 sys drwxr-xr-x 2 root root 0 Nov 29 17:01 tmp drwxr-xr-x 5 root root 0 Nov 29 17:00 usr drwxr-xr-x 2 root root 0 Nov 29 17:01 var# cd /# umount /mnt# ls bin etc init mnt proc sbin tmp var dev home lib opt root sys usr# [/b] --- Quote End --- Check rootfs in mnt dir. <div class='quotetop'>QUOTE </div> --- Quote Start --- BusyBox v1.1.1-pre0 (2006.04.20-12:52+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # mount -t jffs2 /dev/mtdblock0 /mnt# cd /mnt# ls -l drwxr-xr-x 2 root root 0 Nov 29 17:00 bin drwxr-xr-x 6 root root 0 Nov 29 17:00 dev drwxr-xr-x 4 root root 0 Nov 29 17:00 etc drwxr-xr-x 3 root root 0 Nov 29 17:00 home lrwxrwxrwx 1 root root 10 Nov 29 17:03 init -> /sbin/init drwxr-xr-x 2 root root 0 Nov 29 17:01 mnt drwxr-xr-x 2 root root 0 Nov 29 17:00 opt drwxr-xr-x 2 root root 0 Nov 29 17:01 proc drwxr-xr-x 2 root root 0 Nov 29 17:00 root drwxr-xr-x 2 root root 0 Nov 29 17:00 sbin drwxr-xr-x 2 root root 0 Nov 29 17:01 sys drwxr-xr-x 2 root root 0 Nov 29 17:01 tmp drwxr-xr-x 5 root root 0 Nov 29 17:00 usr drwxr-xr-x 2 root root 0 Nov 29 17:01 var# cd /# umount /mnt# [/b] --- Quote End --- Q1: How to do that next step ? Q2: If i want to store some files in flash with using jffs2. How to do it ? Can I use "nios2-flash-programmer" command to store files to flash in sdk shell ? or i need to change specific format for programming flash. Thx !11 Replies
--- Quote Start --- originally posted by hippo@Jun 4 2006, 06:13 AM good. you don't need the dirs for rootfs in jffs2 now. you can use jffs2 mount all for user data.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15866)
--- quote end ---
--- Quote End --- hi hippo Thank u ! OK ... I will erase all dirs and save user data in jffs2 dirve. jay
