21 years agoHow to use Compact Flash in eCos?
Hi. I'm having problems accessing the compact flash card in eCos. I tried a program that mount the filesystem to / and write a file to it. But the program hangs when I try to open a file. I have ...
21 years agoThe most common cause of error when accessing compact flash from eCos is with using the correct device name. If you have called your device "my_cf" in sopc builder, then you would normally need to use the device name: "/dev/my_cfa/1" (Note the extra "a") in the call to mount(). However it is possible that you have a compact flash card which does not contain a master boot record, particularly if you have had to reformat it after running the cf_ide_test's. In this case you should access the device as "/dev/my_cfa/0".
