21 years agohow to use CF card in uclinux?
I use cyclone board and the system detected CF card, but have error. so I can't format CF card use command: fdisk /dev/hda help me! thanks a lot.
21 years ago --- Quote Start --- originally posted by niosfan@Jan 7 2005, 12:37 PM hi,
i tried compiling the "cf_ide_test" project in the downloaded cdcomponent.zip but got lots of compiling errors; i do not need to install linux , do i ???
have you been able to compile cfcomponent successfully ?
i tried it for 1s40fullfeatured using niosii v1.01 but
got compile errors (see below); did you have to modify
any code (eg how did you# define cf_ide_base , "cf",.... and the file altera_avalon_cf_regs.h is installed but the compile didn't see it)
and which version of niosii you used? maybe v1.01 is too
new?)
thanks # ####################################################
error *** [obj/ideutils.o] error 1 cf_ide_test_0_1s40
error# error this ide utility requires a compactflash
interface component named "cf" ideutils.c
cf_ide_test_0_1s40 line 16
<snip> --- Quote End --- Nope, I didn't try to compile the project that came with the cf_component. I believe I used linux.ptf for my development board. I don't know what you'd use for an S40 development board. Look for the# defines here. C:\ALTERA\kits\nios2\components\altera_avalon_cf\inc Opinions now, since I don't have the answer: Linux has support for the cf's VFAT filesystem. Your software must support VFAT - not just the IDE interface, but a real live PC-readable filesystem - to use the cf card properly. Make sense? Unfortunately, the kernal and filesystem projects I created in November no longer work. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif How distressing. I'll be coming back to it next week, I hope. Maybe one of the experts can get more detailed info for you.
