21 years agohow to use CF card in uclinux?
I use cyclone board and the system detected CF card, but have error. so I can't format CF card use command: fdisk /dev/hda help me! thanks a lot.
21 years agoYou are using the pre-built linux.sof core that is included with the Nios II Linux distribution? It has all the pins appropriately assigned already. If you are using your own custom core, I can post the pin connections and pin assignments that are needed.
Dennis Scott Microtronix Datacom Ltd.
