21 years agohow to use CF card in uclinux?
I use cyclone board and the system detected CF card, but have error. so I can't format CF card use command: fdisk /dev/hda help me! thanks a lot.
21 years agoI use Microtronix linux core and CF_Component and CF_qp which was downloaded from this forum, I think it maybe the problem of hardware, I use altera cyclone board;
<div class='quotetop'>QUOTE </div> --- Quote Start --- If you are using a Cyclone board from Altera, the booting message "CF: ctl=1" means the CF controller is not powered, thus won't work correctly. You need a message like "CF: ctl=3" in order to make the Linux driver work.[/b] --- Quote End --- but how to power the CF controller? is there anything need to be notice such as pin assignment when use CF card of altera's cyclone board? thank you.
