21 years agohow to use CF card in uclinux?
I use cyclone board and the system detected CF card, but have error. so I can't format CF card use command: fdisk /dev/hda help me! thanks a lot.
21 years agoHi Xlking,
Are you using the Linux core Microtronix provides, or your own customized core? It looks like the driver could not get correct data from the CF card. If you are using a Cyclone board from Altera, the booting message "CF: ctl=1" means the CF controller is not powered, thus won't work correctly. You need a message like "CF: ctl=3" in order to make the Linux driver work. I am inclined to think it is a hardware issue. Regards, wentao
