20 years agohow to upload the linux in EP2C35 Board
Dear all I have only a board of EP2C35 (Altera dev kit), but i don't known how to run the linux . i select the Cyclone dev kit or stratixii config.but when i select the Upload the ker...
20 years ago --- Quote Start --- originally posted by hootsmon@Feb 15 2006, 07:40 PM you are correct; the nios2-flash-programmer command syntax is changed in 5.1.
1) start a nios ii sdk shell (sopc builder --> tools --> nios ii sdk shell)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12731)
--- quote end ---
--- Quote End --- To all you noobies, in 5.1, there is no Nios II SDK Shell menu item under tools. In fact, if you're following the "Linux Quick Start Guide", you do all this not in SOPC builder, but in the Eclipse IDE. As such, there is no way to launch the SDK Shell from the Eclipse IDE. To fire up the Nios II SDK Shell, do this: Start-->Programs-->Altera-->Nios II 5.1-->Nios II SDK Shell
