20 years agohow to upload the linux in EP2C35 Board
Dear all I have only a board of EP2C35 (Altera dev kit), but i don't known how to run the linux . i select the Cyclone dev kit or stratixii config.but when i select the Upload the ker...
20 years agoHi Alex,
You are correct; the nios2-flash-programmer command syntax is changed in 5.1. 1) Start a Nios II SDK Shell (SOPC builder --> Tools --> Nios II SDK Shell) 2) At the CYGWIN command-line, type.... nios2-flash-programmer --base=0x0000000 {yourPath}/vmlinux.flash If all goes well, uploading to the device should take a minute or so. Later, you can use exactly the same method to upload 'romfs.flash' also.
