22 years agoHow to support the TFT LCD in Nios II
Sir, Plese help! I want to use the framebuffer to support a TFT lcd.The Lcd driver chip is Epson's s1d13506tm. First,How to cofigure the linux kernel v2.6(Microtronix Nios® II ...
19 years ago --- Quote Start --- originally posted by berkul@Oct 15 2004, 12:59 PM tlaskowski,
i'm finishing my course at college, and i would like to know if there's a way to plug a vga display in my nios board.
i'm working with real time image processing and i need a vga display to show the results.
so, how can i plug a display? do i need an expansion board or anything like that? or it's a little bit easier and i can write a c/c++ code and use it?
please help me, i'm a little bit desperate ... thank you ...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=2115)
--- quote end ---
--- Quote End --- I'm in the same case. I can't use a lancelot daughter board, and i need a IP VGA in order to use a CRT or LCD on the VGA port of my Stratix EP1S10F780C6 I'm Using quartus II. Can someone help me? thanks.
