20 years agoHow to Startup application automatically?
Hello. I use Nios2 dev kit(Stratix2). I want to start application after power on without PC. (The application controls LED only.) I checked the following post, http://www.niosforum.c...
20 years ago --- Quote Start --- originally posted by jdhar@Apr 5 2006, 01:06 AM use inetd and telnetd to get into your system. i haven't seen an ssh server, but maybe you can look into it.
just use busybox to compile inetd and telnetd, and then you can telnet into your board once it has an ip.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14023)
--- quote end ---
--- Quote End --- Hi jdhar, I'm wondering how is that done ! Does uClinux start automatically when the board is powered on so I can connect to via telnet. Warm Regards
