20 years agoHow to start with?
Need to port uCLinux on Nios II. Please guide (mail, suggest doc/books/tutorials)
on how to start with? Regards6 Replies
You could download the microtronix distribution and read the read-me files included there. They have a simple step-by-step tutorial which will have you running uCLinux in less then an hour!
--- Quote Start --- originally posted by wgoossens@Oct 19 2005, 12:19 PM you could download the microtronix distribution and read the read-me files included there. they have a simple step-by-step tutorial which will have you running uclinux in less then an hour!<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10442)
--- quote end ---
--- Quote End ---
thanks for the reply,
Got thr microtronics distribution I am following the Linux Quick Start Guide Creating Linux Kernel Project In IDE while creating new project (say) kernel_first after selecting proper ptf (I have tried with 1C20 and 1S40) when I click on Finish in New Project Wizard it gives error: Project cannot be created Reason: Resource /kernel_first/build/arch/nios2nommu does not exist How to resolve this?Whats the reason for this error? Thanks and Regards - Altera_Forum
It looks like you haven't installed the uClinux plugin correctly.
Note that installing the plugin in a directory with a space in its name (e.g. c:\program files\ucLinux) doesn't generate errors while installing, but does when you're trying to use it... - Altera_Forum
--- Quote Start --- originally posted by wgoossens@Oct 19 2005, 04:53 PM it looks like you haven't installed the uclinux plugin correctly.note that installing the plugin in a directory with a space in its name (e.g. c:\program files\uclinux) doesn't generate errors while installing, but does when you're trying to use it...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10452)
--- quote end ---
--- Quote End --- I have reinstalled... This time taking care there are no spaces in the names of folders still I am getting same error Regards
Looks like version issue:
I am trying with Nios II Destribution 1.4 which supports Nios II 5.0 IDE Regards, Rahul
