21 years agoHow to share signals on Avalon bus ?
Hi all, after updating (Quartus II to version 4.2 and NIOS to 1.1) my CPU didn't run anymore due to obscure reasons (e.g. bit swapped addresses on some ports). That's why I've tried to...
21 years agoJesse,
again about problems with 'Create New Component' ... --- Quote Start --- originally posted by jesse@Dec 21 2004, 08:10 PM 2. edit the .ptf file of the component you made with component builder and turn on "is_shared" in the relevant slave signal sections. a signal that 'is_shared = "1"' will be shared per tri-state bridge. --- Quote End --- .. but everytime compilation is started the .ptf file is replaced by its original contents and any altered parameters are lost? Can I start compilation without this update process? Thanks in advance Mike
