20 years agoHow to setup a driver on uClinux ?
Hi all ! I am using Microtronix uCLinux 1.4, Board Cyclone 1C12 Eval edition. When developing a driver, I did not find any commands of module installing: - make - insmod - rmmod ...
20 years agoI'm so sorry about the broken link...
it links to my question how to build .ko file question about building a module (http://www.niosforum.com/forum/index.php?act=st&f=18&t=2411) if it still doesn't work, you can find it on page 3 in the uclinux section of this forum. for testing you'll have to transfer your module in your niossystem of course. Here is a little example, how to use the commands. Lets assume your module name is 'Hello_Kernel': firstbusybox insmod Hello_Kernel" insert your module then you'll need make it visible in your filesystem: mknod "Hello_Kernel" c a b" a and b are the major and minor numbers defined in your module code. So put will have to put the numbers instead of a and b. c is an option ! to access the module in your user application program use the open(...) command. The name of the module to be opened is "Hello_Kernel". --- you unload your module with rmmod. i recommend to read 'Linux device drivers- 3rd Edition' by Corbet & Rubini. Its published by O'reilly. there is also an online version. The online version covers an older kernel. But i don't have the link right now.
