15 years agoHow to set up uClinux autorun
Hi, all!
im following instructions from nioswiki to run uClinux noMMU on FPGA EP3SL150F1152c3 i've done it. now i have a problem to set up autorun. i have a script, and i want to start it automaticaly after uClinux's start. i know i should add to /etc/rc way to my script. but this way is bad for me 'cause i have uClinux in RAM. so i need to edit rc before(or while) compiling kernel to zImage how should i make it?2 Replies
The rc file in the image comes from vendors/Altera/rc
Most of the rest of /etc is in there too. Replace Altera with your vendor if you made your own directory. - Altera_Forum
Ou, thanx a lot!
