21 years agohow to set the ethernet speed
Hi I am looking for a solution to force the lan91c111 ethernet controller to 10baseT (as the board I have does strange things at higher speeds). I tried to understand the driver code in eCOS,...
21 years agoThanks a lot for your hint, it works great!
(I use the second method you explained in your reply) Greetings Yves
