15 years agoHow to set Idle state ?
Hello, I'm a new user so be gentle :) I need to create an Idle state, I have ISR called by the clock every 1 ms, and I need to get rid of the for(;;) loop in the main function this is my...
15 years ago --- Quote Start --- @dsl: I must object...... It does save power Maybe I didn't explain it good enough. Well I am only a softi....;-) Take a look at this thread http://www.alteraforum.com/forum/showthread.php?t=19136&highlight=reduce+power+consumption Even if it's not much but actually this approach is saving power..... --- Quote End --- How much power? Did you take a measurement? If you post "this approach is saving power" - then please post how much savings so user's can benefit from this approach and know if it is worthwhile to implement. Bill
