16 years agoHow to send data using rs232?
I want to send data using rs232. I'm using DE2 kit. How to i write a program doing this operation?
16 years ago --- Quote Start --- thank you for your replay i want to ask about SOPC BUILDER , what software do i need to use ???do i need to install altera moniter program and is there any other program that i can work with ?? and how i will integrate the SOPC builder to my project ?? and i use this program it gave me this error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: FAILED Leaving target processor paused... http://www.alteraforum.com/forum//proweb/misc/progress.gif --- Quote End --- Hello There, 1.All you need to do is to just add UART in your system design in SOPC builder, and then generate new bsp. it will solve your first problem. 2. in your eclips environment, ther you will find debug option just click on them and then enable usb blaster...this will solve your second problem. gud luck
