21 years agohow to send a file to fpga through jtag uart?
hi,everyone! i want to sent the file (for exmple a.dat)of host through the jtag uart to the sdram,which in up3 board.i have get some exmples as for the message sent by uart to host,not the file. ...
21 years agodear friends ,
iam having NIOS II 5.0v , my target board is (cyclone)UP3 board , i had seen ur discussion on Filesystems , i had tried to use HOSTFile system in NIOS II IDE , but iam not sucessfull in it , IS there any option to be enable while creating .bdf file , I have components in SOPC builters such as (Jtag-uart , sdram,sram,..)but i didnt have included UART(Rs232), As per the Help contents in NIOSII IDE , i enabled the option systemlib->system componets ->Host file system ..... but iam not posible to read and write .I even created the specified file (read.txt and write,txt)in the workspace , for read and write .. but iam not possible to successed . i have another doubt , HostFs is not possible to perform in Run mode only in Debug mode means , then what is the use ... then what is the difference b/w run and debugg mode in Nios II IDE eagerly waiting for the reply. regards , Murugan.b
