14 years agoHow to run Nios program out of SRAM
Hello, I am a beginer, and I was using a very old version of NIOS II, version 1.0. I made some changes in the processors code. Now I want to load the code in the SRAM and update the NIOS II to...
14 years agoIts difficult to make specific suggestions based on the description you provided. Note of course that the linker script assigns the various program sections to each of the memory regions. Later nios2-download can be used to install your test program into memory. There is a linker script tab in the bsp gui.
