20 years agoHow to run '"hello"
Dir all, According to this netpage: http://nioswiki.jot.com/wikihome/operating...duleprogarmming (http://nioswiki.jot.com/wikihome/operatingsystems/moduleprogarmming) I made a zImage a...
20 years agothe last make should be "make linux image", not "zImage", because we are in uClinux-dist-test.
make linux will build zImage. make image will put zImage in images/zImage. I have updated the wiki. But it still has problem in modprobe, which may be a bug in the old busybox. I will check the problem later. For now, you can do it without modules, and build directly in kernel, ie, <*> example hello module There is an example driver in Chinese from Alex.liu, http://www.icwin.net/showartitle.asp?art_id=8452&cat_id=52 (http://www.icwin.net/showartitle.asp?art_id=8452&cat_id=52)
