20 years agohow to run gdb debugger under uclinux OS
I have compiler and down load uclinux to target board and it works fine. Next I need to know how to debug application code (run gdb server ???) Is there some one could help me ? thanks -- Wenguang1 Reply
i think you find someting about this in the linux-docs:
the location of files depends on the installation path and program version. And try the search function of this forum. I guess someone else has done this before.C:\altera\kits\nios2_51\documents\linux
