12 years agoHow to return value(s) in NIOS interrupt (ISR) function?
In the reference the return value is void, but how about I want to allocate a new variable in ISR and access it later in the main function? Thanks!
12 years ago --- Quote Start --- You can use global variable which can be accessed in any function as well as in ISR routine. --- Quote End --- However in my case, the variable is allocated dynamically, the size of the variable is unknown until ISR is triggered. Can I declare the global variable and then define its memory allocation later on?
