21 years agoHow to reset a single component
Lets consider following scenario: I have a PCI card equipped with a cyclone2 device. It is programmed with an SOPC builder system which contains a NIOS2 core, a PCI bridge and several other c...
21 years agoMY first thought was to write a container for the NIOS core with an additional slave port which contains a single bit register. The output of this register could be ORed to the SOPC builders reset line - but i don't know if this will compile with future NIOS versions???
