21 years agoHow to reset a single component
Lets consider following scenario: I have a PCI card equipped with a cyclone2 device. It is programmed with an SOPC builder system which contains a NIOS2 core, a PCI bridge and several other c...
21 years agoMy problem is more or less both of them:
I want to set the NIOS in reset state via PCI bridge without affecting all other devices - then do the update - and finally release the NIOS reset again. Unfortunately, your solution is not applicable because i don't have external RAM, and internal RAM is very limited....
