21 years ago>>How to repair an Excalibur Development Board?
guys, bad luck! two of my device was borken, after a programming. device 1) the led7 is on, able to program, but if I press the reset button, it's all down except led7 and the fpga was...
21 years agoAre you talking about a real excalibur dev board with an ARM device? Or a Nios dev board?
For Nios dev board, just power the board down then up, open an SDK window, (hopefully you are on later version of Nios) type ns recovery_configuration_apex_20k200.sof let it download then type nr default_board_image_apex_20k200.flash let it download this is all documented in the kit. Tell me if this doesn't work. if ns doesn't work, you have an old kit. You'll have to open Quartus and download the sof through the programmer.
