20 years agoHow to rebuild a lost CFI table
When I tried to download my design in to the Nios2 board, I got the "No CFI table found at address 0x01000000" error from the Nios2 IDE. I followed the instructions in the User Guide of Programmer an...
19 years ago --- Quote Start --- originally posted by slacker@Jan 30 2007, 06:00 PM be sure to double check your settings in the sopc builder component. also, just as an aside, has this ever worked in the past? or, are you just starting to attempt this on a new(ish) board? if it's the latter, you need to double check everything....and, don't just run the memory test example, but actually step through the cfi initialization routine to see exactly where it's failing.... then, perhaps, it makes sense to use signal tap to help narrow the problem down.
good luck, and welcome to the wonderful world that is the cfi flash "standard".
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21043)
--- quote end ---
--- Quote End --- I haven't personally used it in the past, but a TA tells me that he's gotten it to work before, but he is stumped with this problem. We are using the Altera DE2 board, for what it's worth. If this is the CFI club initiation, I'm not sure I even want to be a member anymore http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
