11 years agoHow to reboot Simple Socket Server ?
Hi, I've implemented the Simple Socket server on a custom board. All is working fine, but I'd like to be able to start the board without the ethernet cable being connected (the server is not th...
11 years agoI think I've "dirtly" solved my problem. Before calling netmain_init(), one must close all sockets (including the primary socket, closed with socketclose(fd_listen) ), and then force the variable ifNumber to 0. Call netmain_init() and then recreate the primary socket, socket(...), bind(...) and listen(...) as in the beginning of the SSSSimpleServerTask() example.
If you have any other better solution, don't hesitate ...
