11 years agoHow to read signed values from FPGA in VHDL to Nios II system
Hi, I am reading a 14-bit signed value from a 14-bit vhdl port into a 16 bit signed variable in Nios II. There is no way for me to define it as 14 bits since the standard are alt_8, alt_16 a...
11 years ago --- Quote Start --- Why not just sign extend? output <= resize(a, a'high+2, a'low); --- Quote End --- When using integer conversion one doesn't need to know the size difference when writing the code - it's more portable. Eventually one will forget why 'high+2 was used. Odds are the synthesis output is the same for both.
