11 years agoHow to read signed values from FPGA in VHDL to Nios II system
Hi, I am reading a 14-bit signed value from a 14-bit vhdl port into a 16 bit signed variable in Nios II. There is no way for me to define it as 14 bits since the standard are alt_8, alt_16 a...
11 years agoI thought of a better way - you shouldn't (can't) multiply because that preserves the sign, which is wrong. Shifting is OK, but it's too specific.
Use the built-in type conversions - convert the 14-bit to an integer (which should preserve the sign), then convert that integer to a std_logic_vector with the proper size for the Avalon port: port <= to_std_logic_vector(to_integer(data),port'size); You get to fix the syntax errors.
